When heat is directed to the floor there is still some coming out of the panel. Is this an actuator problem if so, which one?
Dec 7, 2019 at 5:47 AM
✓Experienced Mechanic
Chances are the mode door actuator needs calibrated. The vehicle is still under warranty. Have you contacted a dealership? They should take care of it for you.
Dec 7, 2019 at 3:06 PM
48BWRICH
MEMBER
What is involved in the calibration? How long would it take to have it done at the dealer?
Dec 7, 2019 at 10:47 PM
Basically, a scanner is used to do it. It requires a high end scanner and not one that you can buy at a parts store.
