Heater blowing cold engine gets hot
150,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
DSPANO99
Engine gets hot but heater will not blow hot air.
Oct 11, 2018 at 8:09 AM
  • 110,251 POSTS
First, check to make sure it isn't low on coolant. The is the most common reason heaters don't work and engines get hot. Take a look through this link, specifically number 8.
https://www.2carpros.com/articles/how-a-car-heater-works
Let me know what you find.
Oct 11, 2018 at 12:56 PM
DSPANO99
I replaced the thermostat and that solved the problem. Thanks
Oct 15, 2018 at 3:14 AM
  • 110,251 POSTS
Great! Let us know if you have questions in the future.
Oct 15, 2018 at 10:06 AM
