Heater blowing cold air
86,000 MILES • V6
DANA DONALDSON
Flushed coolant. Flushed heater core and replaced thermostat.
Nov 12, 2016 at 11:10 PM
HMAC300
  • 48,601 POSTS
I am assuming you have a 3.5 you never gave size of engine. see pictures for instructions then when finished pull HVAC fuse inside car for sixty seconds with key on so actuators will reset.
Nov 13, 2016 at 12:16 AM
DANA DONALDSON2
  • 8 POSTS
Which HVAC fuse. And with car running or just key on? I tried pulling all four of the fuses on the inside panel. It is blowing out semi-warm heat but not hot. The far left that was warmer than the others . Also when I turn car off blower keeps running. I have to turn heater off then restart car and turn ignition back off for it to stop .
Nov 14, 2016 at 1:04 AM
DANA DONALDSON2
  • 8 POSTS
Both heater core hose are hot.
Nov 14, 2016 at 1:07 AM
DANA DONALDSON2
  • 8 POSTS
Oh, and I had already bleed the cooling system.
Nov 14, 2016 at 1:08 AM
HMAC300
  • 48,601 POSTS
the fuse is in the body control module which is located beneath center console. see if the actuator in picture is getting power if it is then it may be bad. if not it will need to be scanned for codes.
Nov 14, 2016 at 2:27 AM
DANA DONALDSON2
  • 8 POSTS
Where is the actuator located and how do I get to it?
Nov 14, 2016 at 5:26 AM
HMAC300
  • 48,601 POSTS
i'm sorry I sent the wrong pic to many things going through my mind. it's by the blower so you will need to remove panel below blower
Nov 14, 2016 at 7:01 AM
DANA DONALDSON2
  • 8 POSTS
Sorry where is the blower located is it behind the glove box or behind the panel in center of dash
Nov 14, 2016 at 7:24 AM
DANA DONALDSON2
  • 8 POSTS
Sorry need a little bit more detail I'm a girl that doesn't have that much mechanical experience
Nov 14, 2016 at 7:25 AM
HMAC300
  • 48,601 POSTS
on the passenger side there is a small panle that may need to be removed the blower motor is right there as in the pic the actuator is right where the pic is I think it's a 7mm head on the screw
Nov 14, 2016 at 8:19 AM
DANA DONALDSON2
  • 8 POSTS
Ok thanks
Nov 14, 2016 at 10:08 AM
  • 55,865 POSTS
Please let us know what you find so it will help others.
Best, Ken
Nov 16, 2016 at 7:17 AM
