Heater blower only works on high fan speed
80,000 MILES • 1.8L • FWD • MANUAL
JAYJAY33
Hi there, i been having problems with my heater blower fan for a while. Then it started only working on high only. I replaced the fan a resistor but still only working on high. What else could cause it only working on high?
Dec 1, 2016 at 11:50 PM
  • 55,770 POSTS
Hey Jay,
There is a relay that controls the lower speeds, I don't have any info for wiring diagrams for this car since we are in the states. Check the owner's manual to see if it says anything, then swap some other relays around to see if you can find the right one.
Please let us know what you find so it will help others.
Best, Ken
Dec 4, 2016 at 5:51 AM
JAYJAY33
Ive read something info on the web about a blue relay on the back of the fuse box on the passenger side of the dash which im waiting for it to be delivered. Will let you know if this works. Thanks for the reply
Dec 4, 2016 at 8:19 PM
  • 55,770 POSTS
I look forward to the result, hope all is well.
Dec 5, 2016 at 3:05 AM
JAYJAY33
It was the blue relay on the back of the fuse box. All fixed now
I just wanted to recap what went wrong with my car so other vauxhall user don't suffer with this problem.
If you have ever been through a car wash or had plenty of rain and noticed the front passenger side footwell is wet then this for you.
There is a drain hole in front of the pollen filter. When this blocks up water can only drain out one way and that is through your blower fan. Which then end up in your car i.e passenger side carpet.
This water will damage and rust your fan motor. 1st sign is the resistor blowing. You will only be able to use 4 on your control settings this will also cause damage to the relay and fuse. The resistor controls settings 1, 2 and 3 by slowing the fan down.
If this problem is left you will end up having the replace the blower fan which i did. This is costly.
Unblock the drain hole and this solve the problem and not cost you a fortune in the future. I hope this help anybody having the same problem.
Dec 9, 2016 at 1:56 AM
JAYJAY33
Sorry about spelling and grammer
Dec 9, 2016 at 1:58 AM
  • 31,937 POSTS
Thanks for all that info, it will be a great help to European members and Australian members with Holden Vectra's as these are much the same vehicle
Dec 9, 2016 at 3:43 PM
