Heater blower speed fluctuating
80,000 MILES
SOTOSON
The blower when on it is intermittent, goes fast and then slows down. I changed the resisters but the problem remains.
Dec 27, 2019 at 6:48 PM
Good morning,
Is this for the front or rear blower motor?
Dec 27, 2019 at 9:06 PM
SOTOSON
Front blower, heater in the back is fine.
Dec 28, 2019 at 3:15 AM
I posted the procedure below and attached some pictures for you for the replacement.
Removal Procedure
If equipped, remove the sound insulator panel. Refer to Instrument Panel Insulator Replacement.
Remove the blower motor insulating cover screws.
Disconnect the electrical connector from the blower motor.
Remove the blower motor insulating cover.
Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
Dec 28, 2019 at 3:21 AM
SOTOSON
Thank you, just want to verify that is the motor that is causing the operate intermittently.
Thanks
Dec 28, 2019 at 3:30 AM
If you replaced the resistor, then the motor sounds like it is locking up or seizing while it is running.
Dec 28, 2019 at 3:37 AM
SOTOSON
Thank you, that took care of the problem. I appreciate you help.
Sotoson
Dec 28, 2019 at 5:53 AM
You are welcome.
Always glad to help.
Dec 28, 2019 at 6:00 AM
