Heater module removal
160,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
ALBAENRIQUE
Need to remove and check heater module located behind blower motor, hard to get to. Blower motor already removed.
Jul 10, 2018 at 4:45 AM
Good afternoon.
Yes, it is tight. I peel back the rug and the insulation to give me more room to access the screws. I also only loosen the inside screw and remove the front two. Then it will release forward and down.
Jul 10, 2018 at 7:10 AM
