Heater blower has stopped working on all spends?
69,500 MILES • 1.8L • 4 CYL • 2WD • MANUAL
SMIDDY1
Heater blower has stopped working on all spends. Tested the resistor on the top and I have continuity. Ac light has also gone now. Replaced all the connectors to the relay as were all loose and corroded. Fuses are all ok.
Feb 3, 2026 at 2:46 AM
  • 55,710 POSTS
It sounds like the blower motor went out, do you have power and ground to the blower motor? This guide will help you see.
https://www.2carpros.com/articles/how-to-test-an-automotive-hvac-system-blower-fan-motor-a-detailed
Please go over this guide and get back to us.
Feb 3, 2026 at 8:18 AM
