heater blend door control
145,000 MILES • 2.5L • V8 • 4WD • AUTOMATIC
KBUK
i need the plastic sleeve that connects the blend door pin to the control unit. where can i get one?
Nov 20, 2021 at 1:27 AM
Are you talking about the actual pin that connects to the door inside the unit which inserts into the actuator?
I attached pictures below of what I am talking just to make sure we are on the same page.
I also attached the replacement info of the actuator for you or anyone else that needs it who visits this page.
If this is what you are referring to then I am not aware of anyone who sells this so you may need to go to a salvage yard and find one out of a unit.
Please review the attached info and let me know if you are talking about something different. Thanks
Nov 21, 2021 at 6:05 AM
WISKER
try it here https://www.moparoriginalparts.com/ maybe they have the parts you're looking for.
Nov 24, 2021 at 9:46 AM
Thanks for the addition. That is a great source so it is worth a try.
Let us know what you find or how this turns out. Thanks
Nov 24, 2021 at 11:42 PM
