Heater and defroster does not blow hot on driver side
2013 FORD EDGE
45,987 MILES • AUTOMATIC
SHIRLEY HUFHINES MCCONNELL
The heat and the defroster blow hot air on passenger side, but only blows cold air on driver side. The two vents in the middle the driver side blows cold air, while the passenger side blows hot air.
Nov 14, 2018 at 1:25 AM
There is a blend door motor under the driver side of the dash that is the most common reason for this failure. I attached pictures and procedures for the replacement (BELOW).
Procedure
Temperature Blend Door Actuator - LH
Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
1. Remove the steering column trim panel.
- Remove the 2 steering column opening trim panel screws.
- Disengage the steering column opening trim panel from the retaining clips.
- Disconnect the electrical connector and aspirator hose, if equipped.
2. Remove the 3 LH temperature blend door actuator screws.
3. Disconnect the LH temperature blend door actuator electrical connector.
4. Remove the LH temperature blend door actuator.
5. Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
LH temperature blend door linkage only
6. Detach the 2 retaining tabs and remove the LH temperature blend door linkage.
7. To install, reverse the removal procedure.
Nov 14, 2018 at 2:05 AM
NESIA WILSON
Be sure to get a new part from the dealer if you want it to last, thanks for the diagrams helped me.
Jan 27, 2020 at 3:29 AM
