Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jeep
Liberty
Climate Control
Air Conditioner
Drain
Heater and air conditioner box drain
2008 JEEP LIBERTY
40,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
ALBERT PELLETIER
MEMBER
1 POST
Drain clogged.
Mar 5, 2018 at 3:15 AM
CARADIODOC
Experienced Mechanic
What is the question? Standard procedure is to squeeze the drain hose to open it up and see if the blockage comes out. Next is to remove the hose, then try to dislodge the debris in the spout.
Mar 5, 2018 at 7:53 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
