Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Le Baron
Climate Control
Heater
Not Working
No heat from heater
1995 CHRYSLER LE BARON
64,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ASKOLDCARGUY
MEMBER
1 POST
For no apparent reason my heater stopped throwing heat but the A/C is working perfectly.
Apr 18, 2018 at 8:39 AM
Experienced Mechanic
Is sounds like the engine could be low on coolant or you have a temperature blend door actuator that is out. Here is a guide to help us see which:
https://www.2carpros.com/articles/car-heater-not-working
Check out the diagrams (below) This is the fresh air actuator.
Please run this test and get back to us.
Cheers, Ken
Image (Click to enlarge)
Apr 20, 2018 at 9:11 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
