Heater air blend actuator
140,000 MILES • 3.5L • 6 CYL • AUTOMATIC
GMORENO
As i line up lever and cable/rod to position on gears on actuator and have the temperature knob on say hot air full, as soon as I connect wire connector to actuator the actuator reverses temperature to opposite hot lever/rod/reverses or turns to cold. If I line up lever/rod to cold air with actuator on that position as soon as I connect wire harness, the actuator turns to opposite temperature.
Does this make any sense?
Oct 23, 2017 at 11:24 AM
  • 55,746 POSTS
Yep it sounds like the actuator is bad becasue that got the polarity of the motor that is inside the actuator backwards.
Is it an OEM part?
Cheers, Ken
Oct 25, 2017 at 9:53 AM
GMORENO
Hi Ken and thank you for replying. It is a part from a salvage yard, I did not thought about polarity
Oct 25, 2017 at 12:28 PM
  • 55,746 POSTS
Was the actuator from the same year of car?
Oct 27, 2017 at 4:04 AM
GMORENO
Ken
It was the same part number.AW063700-8160
Oct 27, 2017 at 9:09 AM
  • 55,746 POSTS
Hum, thats a good one there it should work. I wonder if the car you took it out of had the same problem. I will post this question in our expert forum to see if we can get a response. We have some good electrical guys here.
Please stand by.
Oct 28, 2017 at 9:13 AM
WRENCHTECH
  • 20,760 POSTS
It could also be attempting to go through calibration which will send it to both extremes.
Oct 28, 2017 at 9:22 AM
GMORENO
Hey Ken and WrenchTech
I finally got it working, the 12V motor was inverted in polarity, after cleaning and aligning gears and lever/shaft and temperature know the actuator dial position itself "home". I believe cleaning gears and using dielectric grease on the dial circuitry helped a great dial inside the actuator, knob controls temperature like a charm.
Thank you both, I will post pictures later to illustrate this problem better.
Oct 28, 2017 at 10:17 AM
  • 55,746 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Oct 28, 2017 at 10:48 AM
