Heater/AC will not turn on
2003 CHEVROLET AVALANCHE
84,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
RSTREB223
The heat/AC unit will not even light up when I turn it on, so I am not getting anything. I checked the fuses and replaced them and still nothing.
Mar 18, 2018 at 7:37 PM
Good morning.
Do you have auto climate control?
Do you mean the control head or the AC button that will not light up?
Mar 18, 2018 at 7:50 PM
RSTREB223
I think I have auto climate control, and when I press the power button to the heater/AC nothing lights up and nothing turns on.
Mar 19, 2018 at 1:32 PM
Okay.
I attached a diagram of the system for you. you need to check the two fuses listed for power on both sides as the unit will not work without power.
One fuse box is at the left end of the cluster and the other one is under the hood.
Mar 19, 2018 at 8:28 PM
