Heater/AC only blows cold air
135 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
WM WLLIAMS
Only blows cold air.
Feb 19, 2018 at 1:23 AM
  • 55,781 POSTS
This sounds like you have a problem with the blend door actuator but to be sure lets check the coolant level when the engine is cold to make sure it is full because if it is low the heater will not work.
Cheers, Ken
Feb 20, 2018 at 4:32 AM
