HEATER trouble
115,000 MILES • 2.0L • 4 CYL • AUTOMATIC
BIGGS
  • 16 POSTS
Takes for ever for the heater to heat up even when the engine is warm.
Mar 23, 2017 at 2:35 PM
HMAC300
  • 48,601 POSTS
do what is in the pic to try to re-calibrate the temperature actuator otherwise it may be bad causing the no heat problem.
Mar 23, 2017 at 11:47 PM
BIGGS
  • 16 POSTS
well guys i figured it out, it was a combination of a couple things, after taking a good look under the hood touching hoses for heat i noticed little rusty splashes down by the lower radiator hose so i checked radiator level by removing the cap- even though the reservoir was full of pure green coolant and had never moved above the half way mark on the temp gauge i seen no water in radiator so i filled radiator and of course heater worked perfect so further investigation i disconnected over flow tube at the cap and blew through it or at least tried to ha it was pinched off behind the grill so i straightened it out and whoola the flow was clear , now i i checked for leaks and the radiator is the culprit its leaking around the tank at the cores barely a noticeable seepage. going to purchase a radiator now , thanks for all the input it did get me under the hood again which put me in the right direction, thanks again for your help.
Mar 24, 2017 at 11:13 AM
  • 55,684 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
It was the first thing we say in this guide.
https://www.2carpros.com/articles/car-heater-not-working
Maybe we can get this guide to you sooner next time.
Best, Ken
Mar 27, 2017 at 1:58 PM
