Heater blows cold air on passenger side
157,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
GLBY
  • 6 POSTS
Blowing heat on driver's side but cold on passenger side.Thinks it's the air blender but do not know where it is located.
Jan 11, 2020 at 4:32 AM
  • 110,248 POSTS
I agree. It sounds like the blend air door actuator. First, here is a link that shows in general how one is replaced:
I attached a pic below to help locate the air temp servo (actuator).
Let me know if this helps.
Jan 11, 2020 at 9:46 AM
GLBY
  • 6 POSTS
Still little lost from the diagram. Found the recirculation servo and the one that changes what vent. Both are working. Is there a way to manually open the blend door?
Jan 11, 2020 at 8:06 PM
  • 110,248 POSTS
The only thing you could try is to remove the actuator and move the door. I enlarged the location hoping to make it easier to identify, but I think I made it worse. It is very close to center of the dash.
Jan 12, 2020 at 9:53 AM
GLBY
  • 6 POSTS
Better. Thanks.
Jan 12, 2020 at 6:08 PM
GLBY
  • 6 POSTS
How do you get to it. Do you have to take the entire dash apart?
Jan 12, 2020 at 6:12 PM
  • 110,248 POSTS
If you remove the insulator panel under the dash, it will be tight but you can access it. I'm not going to lie. They are a pain, LOL
Jan 13, 2020 at 10:35 AM
GLBY
  • 6 POSTS
I'll give it a try . Thanks for the help.
Jan 13, 2020 at 7:23 PM
  • 110,248 POSTS
You are very welcome. If you get the chance, let me know how things turn out for you.
Jan 14, 2020 at 9:14 AM
GLBY
  • 6 POSTS
Hi Joe, as promised an update on the air blend door issue. Turned out to be a bad water pump. As soon as it was replaced the heater issues went away.
Feb 28, 2020 at 9:25 PM
  • 110,248 POSTS
I'm glad you got it taken care of. You know, if you would have asked me if I thought the water pump was bad, I would have said no. There is only one heater core, so if one side was hot, the other should have been as well.
Regardless, it's fixed and that's all that matters. Please feel free to come back anytime.
Feb 29, 2020 at 9:33 AM
