Heater puts out warm air no hot air?
87,000 MILES • 2.6L • V6 • 4WD • AUTOMATIC
RREAPER
heater puts out warm air no hot air, with heater on warm air cold air 2 defroster vents do switch I I can switch climate control switch a little bit of change in warm air not very much. Heater hoses get hot in out heater core hoses get hot?
Aug 24, 2024 at 12:42 AM
  • 55,694 POSTS
This can be one of two things either the heater core is partially clogged, which you can flush out using a garden hose, or the temperature blend door actuator is not closing all the way. Please go over this guide to help as well:
https://www.2carpros.com/articles/car-heater-not-working
Here is the location of the temperature blend door actuator so you can remove it and work the blend door pivot by hand to see if it makes a difference, (HVAC system on) van engine warm.
Aug 24, 2024 at 4:59 AM
RREAPER
thank you, a place, to start. I will reply when I check things out.
Aug 25, 2024 at 2:02 AM
  • 55,694 POSTS
Sounds good, let me know what happens please.
Aug 25, 2024 at 2:37 AM
RREAPER
took motor cover off actuator works turns c-wise and cc-wise flushed heater core little debris came out flushed until clear water, refilled core with anti-freeze got a lot more heat? can a little debris make that much difference?
Aug 28, 2024 at 9:43 PM
  • 55,694 POSTS
Oh yes, you would not think it would, but a clogged heater core is a common problem. I would flush the core in both directions for optimal performance.
Aug 29, 2024 at 3:08 AM
