Heater
2000 CHEVROLET SILVERADO
235,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
1JOHNSON
Recently changed heater core and now it blows hot air even when off. Recycle air and a/c buttons will not engage either? Is it possible the intake/outtake hoses could be backwards
Apr 21, 2016 at 4:40 AM
HMAC300
  • 48,601 POSTS
not likely all that would do is where hoses would direct the air. pull hvac fuse inside car for 60 seconds with key on see if it resets anything.recheck your work as well as you may have left off an electrical or vacuum connection.
Apr 21, 2016 at 5:37 AM
1JOHNSON
Thank you
Apr 21, 2016 at 5:41 AM
1JOHNSON
Pulled the fuse, it didn't seem to work. It was worth srry thank you
Apr 21, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
you'll have to get the control head scanned for codes then. also was the a/c recharged after you did heater core?
Apr 21, 2016 at 8:31 AM
1JOHNSON
Have not recharged the a/c yet, but would that cause it to blow hot air when it is off?
Apr 21, 2016 at 8:33 AM
  • 55,433 POSTS
Hey 1johnson,
It sounds like you forgot to plug in one of the blend door actuators, can you please double check for us? Or the blend door is caught on something
Best, Ken
Apr 21, 2016 at 10:02 AM
1JOHNSON
Will do. Thank you
Apr 21, 2016 at 10:12 AM
  • 55,433 POSTS
Please let us know what you find
Apr 22, 2016 at 12:42 AM
