Heater is not blowing air out of the vents
123,345 MILES • 5.9L • V8 • 4WD • AUTOMATIC
ATTICUS 2010
  • 9 POSTS
My truck's heater is not letting an air out of any of the vents . the vent doors actuators are not letting any of the doors open. what can I do? help!
Oct 5, 2016 at 12:12 PM
SATURNTECH9
  • 30,868 POSTS
Have you checked under the hood at the firewall for a disconnected vacuum line?
Oct 5, 2016 at 2:52 PM
ATTICUS 2010
  • 9 POSTS
No, I have not, but thank you. I will look to see and let you now.
Oct 6, 2016 at 2:52 AM
ATTICUS 2010
  • 9 POSTS
I checked the vacuum hoses and there was no leaks.
Oct 6, 2016 at 11:53 AM
SATURNTECH9
  • 30,868 POSTS
So is it only blowing out on the windshield?
Oct 6, 2016 at 2:13 PM
ATTICUS 2010
  • 9 POSTS
I get very little air coming out through the top vent and the middle and bottom. Also when I turn on the heater to hot or cold they are reversed.
Oct 6, 2016 at 2:53 PM
SATURNTECH9
  • 30,868 POSTS
Is this auto climate control or manual controls?That is strange that the temp is backwards.When you move the knob to tell it to come out a different vent does any of the air flow out of any of the vents change?
Oct 7, 2016 at 5:47 AM
ATTICUS 2010
  • 9 POSTS
It's manual, No there is no change on the amount of air coming out.
Oct 7, 2016 at 6:55 AM
SATURNTECH9
  • 30,868 POSTS
Have you checked the control head itself ?for bad connection etc?
Oct 8, 2016 at 5:36 AM
ATTICUS 2010
  • 9 POSTS
How do you go about checking it ?
Oct 8, 2016 at 8:24 AM
  • 55,770 POSTS
this sounds like an actuator is not working or you have a bend door that is broken. Does your truck have a cabin air filter? here are a couple of guides to help you
https://www.2carpros.com/articles/how-to-change-an-air-cabin-filter
and
Please let us know what you find so it will help others.
Best, Ken
Oct 10, 2016 at 10:19 AM
ATTICUS 2010
  • 9 POSTS
We found out that the Heater Blend Door Actuator is the problem , the only thing is that my truck is a 2001 1500 dodge and I can't find one . would like some more help if you know where to get one .
Oct 10, 2016 at 1:42 PM
SATURNTECH9
  • 30,868 POSTS
The blend door controls the temperature do you mean the mode door ?
Oct 10, 2016 at 3:24 PM
ATTICUS 2010
  • 9 POSTS
The part that is broken is the blend door actuator it is not opening that door that it's suppose to open.
Oct 10, 2016 at 3:33 PM
SATURNTECH9
  • 30,868 POSTS
The blend door controls the temperature to make it hotter or colder it doesn't control where the air flow comes out.The mode door controls the air flow.I wil help you find the blend door if that's the one you say is broken.
Oct 11, 2016 at 1:49 AM
  • 55,770 POSTS
SATURNTECH9
  • 30,868 POSTS
That doesn't fit a 2001 dodge ram I used the application guide on the parts listing to check
Oct 11, 2016 at 1:57 AM
SATURNTECH9
  • 30,868 POSTS
SATURNTECH9
  • 30,868 POSTS
There is the blend door actuator if you search that part number on eBay Amazon etc you might be able to find it cheaper.
Oct 11, 2016 at 3:35 AM
ATTICUS 2010
  • 9 POSTS
Yes that is the part that is broken and not working . I also found it on E-bay for that price will check to see if I can find it for a little less then that. Thank you for all your help , you help me a lot.
Oct 11, 2016 at 10:09 AM
  • 55,770 POSTS
Glad we could get it fixed please use 2CarPros.com anytime we are here to help
Best, Ken
Oct 11, 2016 at 11:53 AM
