Heater not working on driver's side only
170,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JB140CENTRAL
  • 8 POSTS
No heat on the driver side only heat on passenger side.
Mar 4, 2022 at 12:52 AM
  • 110,248 POSTS
This is an odd one because it only has one blend air door. This is what determines the air temperature entering the vehicle. On vehicles with dual climate control, there are two, one for each side. This isn't an option here.
So, I need a little more info. First, does the heat work normally on the right side? For example, if you change from heat to cool, does the temperature change? Also, if you place the airflow mode differently, for example, from vents to floor, does it work properly on any other setting?
Mar 4, 2022 at 10:30 AM
JB140CENTRAL
  • 8 POSTS
Hello Joe, I changed the actuator on the blend door thinking it might be the problem it was not, I pulled the heater core out, cleaned it out added cleaner and flushed it out before reinstalling it in the car. Still only heat on the passenger side of the car the heat on passenger side will work on defrost, front facing, and floor it will also change from cold to hot. The driver's side will switch all three positions also but only blow cold air. I pulled the actuator motor off and worked the blend door back and forth and it works fine.
Mar 4, 2022 at 11:35 PM
  • 110,248 POSTS
This is really odd because the heat comes from the same place. Are you certain there are no ducts disconnected or blocked? Also, with the blend door actuator removed, are you able to manually move the door to see if maybe it isn't moving far enough in one way or the other?
Mar 5, 2022 at 9:58 AM
JB140CENTRAL
  • 8 POSTS
Joe,
I have moved the actuator door back and forth, it moves freely, and it functions normal on the passenger's side, one way the air is hot and the other way the air is cold. On the driver's side when I move the actuator door the air stays cold either way, it just does not make sense. I know the serpentine belt is turning okay. Thermostat is okay, the heat gauge is always normal. The air flow from the vents is strong on all three ports. When I had the heater core out, I could look inside a little. It was kind of hard to see but I could not see any blockage and it does seem to blow air great. I was reading some info that said the heater core could have been plugged on one side that is why I removed it from the car and took it into my house and cleaned it , but it was not really dirty and when I flushed it out after cleaning I ran hot water through the core and it was hot completely through so I knew it was not plugged. Jim
Mar 5, 2022 at 11:22 AM
  • 110,248 POSTS
The only thing about the heater core possibly being plugged is that heat comes from the same place. If you are getting heat on one side, it should be on the opposite as well. However, that is the only possibility. When you flushed the heater core, how did you confirm it was clean inside? I ask because at this point, I suspect it is still partially plugged and may need to be replaced.
Mar 6, 2022 at 11:03 AM
JB140CENTRAL
  • 8 POSTS
Joe, like I said, it does not sound right but I took the heater core out of the car cleaned with Prestone cleaner. I flushed it with hot water from a hose, it flushed out both ways freely and the heater core got hot completely throughout as I made sure to feel the core as I was flushing it out. I am going to change the thermostat and the water pump just because they have never been changed, I don't know if it will make any difference.
Mar 6, 2022 at 6:30 PM
  • 110,248 POSTS
I understand, but nothing else makes sense. LOL As far as the pump and thermostat, if the temperature is reaching operating temperature and the vehicle isn't overheating, I'm not sure that it is going to change anything.
I'm going to ask another tech to see what he says. You may get a reply from him. If you don't on a timely basis, let me know.
Mar 6, 2022 at 9:27 PM
JB140CENTRAL
  • 8 POSTS
Thanks, I will be looking for the problem.
Mar 7, 2022 at 1:19 AM
  • 110,248 POSTS
Okay, I was able to get in touch with him. He is suggesting that you run a borescope down that vent to see if there is any evidence of damage or something not working properly. He also added that he felt the blend air door has a plastic linkage and one side may not be opening.
Are you able to get a scope to check? I know that isn't a common tool.
Mar 7, 2022 at 5:23 AM
JB140CENTRAL
  • 8 POSTS
Joe, yes, I do have a scope. I used it to look in the heater core compartment I couldn't see anything damaged. All I could see was the A/C condenser. Nothing seems to look off. The blend door like you said is a single door hinged on one side and the actuator is on the other. I took the actuator off and moved the door by hand, and it seemed to move fine. Should I be able to see the A/C condenser from the heater core compartment with the heat set on hot or should it be covered by another door inside. Thanks, Jim
Mar 7, 2022 at 6:28 AM
  • 110,248 POSTS
Jim,
If you, have it on heat, the condenser should be closed off. When you change temperature, are you able to see the door move? If you scope the opposite side that works, what do you see?
Mar 7, 2022 at 8:49 AM
JB140CENTRAL
  • 8 POSTS
I had the heater core out of the car when I looked into the core cavity. The door for hot and cold opens and closes. What I was wondering is there another door toward the front of the heater box where the a/c core is located, as I can see the A/C core when looking in heater core cavity. I wondered if another door closed the A/C core off when the heat was turned on. I hope I am explaining this good enough so you can get the idea.
Mar 7, 2022 at 9:36 AM
  • 110,248 POSTS
There are a total of three actuators. One is for the temperature, one for airflow direction, and one is a fresh air actuator. I attached pics below of their locations.
Since the airflow actuator is working properly, pull the fresh air door and see if manually moving the door changes the temperature in any way.
Mar 7, 2022 at 9:46 AM
JB140CENTRAL
  • 8 POSTS
I will check the air inlet door actuator because the other doors seem to be working. Thanks, I will let you know.
Mar 7, 2022 at 10:15 AM
  • 110,248 POSTS
Sounds like a plan. Let me know what you find. I'm interested in knowing.
Mar 8, 2022 at 4:55 AM
