For the heater do I adjust temperature to hot?
60,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JCONTER
Just bought vehicle, been using A/C. Winter coming need to use heater. Do I adjust temperature to hot?
Oct 26, 2020 at 10:39 AM
  • 110,248 POSTS
I'm not sure which system you have, automatic or manual temperature control, but yes, you will adjust the temperature knob to hot. There should be an A/C button to press to prevent it from turning on.
I attached a pic of the control panel below, but it isn't clear enough for me to see the label for each switch. If you take a pic of your control unit and upload it for me to see, I will likely be able to tell you which one to use.
Oct 26, 2020 at 10:59 AM
