Heater not working properly, no place for heater hoses to go in the firewall?
215,000 MILES • 3.6L • V6 • 2WD • MANUAL
DAVID MOON
There's no place for heater hoses to go in the firewall! How can I get heat in my truck?
Oct 25, 2022 at 7:10 AM
DAVID MOON
Found them! On the driver's side of the firewall. Never looked at that! Guess I can flush it out and see if it works. Maybe. Is there anything else I need to check?
Oct 25, 2022 at 9:23 AM
  • 110,244 POSTS
Dave, before you flush it do the following to confirm the heater core is the issue.
First, confirm the coolant is full in the radiator (engine cold). If it is and in the reservoir, start the engine and turn the heat on high. Allow the engine to reach operating temp. Once it does, turn the engine off. Feel both heater core hoses to see if both are hot. The return will be a little cooler but should still be hot.
If that is the case, we need to focus on the blend air door. If one is hot and the other is cool, then I would recommend the flush. Make sure to backflush it as well.
Here is a link you may find of interest and helpful:
https://www.2carpros.com/articles/car-heater-not-working
Oct 25, 2022 at 12:18 PM
DAVID MOON
Thanks for the reply. I am flushing the heater core now and have a new thermostat for it also. I'll check for heat in the hoses as you said and let you know what happens. Thanks again.
Oct 26, 2022 at 6:26 PM
  • 110,244 POSTS
No problem whatsoever. Let me know what you find or if I can help in any way.
Oct 27, 2022 at 10:01 AM
DAVID MOON
Heater core was stopped up. Cleaned it and flushed it out and good to go! Thank you for everything.
Oct 29, 2022 at 9:30 AM
  • 110,244 POSTS
Thank you for the update. I'm glad to hear you got it taken care of. Winter is getting closer. LOL
Regardless, please feel free to come back anytime in the future. You are always welcome here.
Oct 30, 2022 at 12:43 PM
