Heater
133,600 MILES • V6 • AUTOMATIC
SANDY NOTHIN ON-ME SIGLOW
I just got this 2003 saturn l300. I cant get the heat and ac to come on. Dials turn but blower wont come on at all. Nothing shows up on the little screen either. I checked the fuses.they are fine. What could be wrong?
Sep 5, 2016 at 10:30 AM
AL514
  • 5,685 POSTS
If you have power at both sides of the fuses, your next check would to check for power at the actual heater control itself. If the digital display isn't showing anything it sounds like there may not be any power going to it (ie. a wiring circuit problem) or the control itself has gone bad.
Sep 5, 2016 at 12:57 PM
AL514
  • 5,685 POSTS
Also if there is a relay that controls that power circuit.
Sep 5, 2016 at 12:58 PM
  • 55,616 POSTS
Please let us know what you find so it will help others.
Best, Ken
Sep 14, 2016 at 11:10 AM
SATURNTECH9
  • 30,869 POSTS
With the key in the run position are you sure the ignition 3 fuse in the underhood fuse and the bcm 2 fuse in the left hand side fuse box both have power to both sides of the fuse?
Sep 14, 2016 at 11:32 AM
