Heater
760,000 MILES • V8 • 4WD • AUTOMATIC
GABBYISHOT
hello I have a question my heater turns on and blows out hot air and then it gets cold after two minutes and stop blowing the hot air what could be wrong
Dec 22, 2015 at 2:18 AM
HMAC300
  • 48,601 POSTS
check coolant level first it may be low if it is have it checked for an internal leak like a head gasket. also pull fuse 5 for 60 seconds with key on it may reset blend door actuator. if fluid is full then have it looked at to see if actuator is working.
Dec 22, 2015 at 10:50 PM
