Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
C1500
Climate Control
Blower Fan
Not Working
Heater fan not working properly
1994 GMC C1500
215,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ALAN.MEEHL
MEMBER
heater display comes on. When you use the fan control from low to high it clicks but the fan does not run?
Feb 6, 2018 at 4:17 PM
JOHNNYT73
Experienced Mechanic
This could very well be a bad blower motor. The click you are hearing is most likely the relay for the blower motor fan.
Feb 6, 2018 at 9:38 PM
ALAN.MEEHL
MEMBER
Thank you for your help. I should have checked the connection. Which I did at the back of the heater control. Now is working fine.
Feb 8, 2018 at 6:00 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
