fuses all look good. are there any fuses in the control head if not how do you test the control head?
Jan 3, 2017 at 3:52 AM
HMAC300
✓Experienced Mechanic
they have to be tested by a mechanic with a scanner to see what is wrong as it may be a body module problem. fuse D20 underhood and F18 inside power relays for fan and fusible link from battery powers control for rear window defogger.
Jan 3, 2017 at 4:04 AM
BOB B
MEMBER
The body module is that the same as a climate control module ?
Jan 3, 2017 at 5:41 AM
HMAC300
no it is different it also supplies power to control for heat/AC.
Jan 3, 2017 at 6:58 AM
BOB B
MEMBER
What does the body module look like and where is it located in the car ?
Jan 3, 2017 at 10:45 PM
HMAC300
you cannot replace it as it needs to be programmed to your car. it is behind right kick panel. there is also a blower control module that is on the heater case behind right side of dash.
Jan 3, 2017 at 11:53 PM
