heater
92,000 MILES
VICKI26
All the pipes are hot. But don't blow hot air in the car what can be the problem?I've check everything I can the pipes are hot till where in go in at the dashbord but no hot air and the pipe with the arow that shows in are cooler then the one comeing out of the dashbord
May 5, 2013 at 6:13 PM
  • 31,937 POSTS
Proberbaly the heat flap door control has failed, many vars these day do not have a heater tap, the heater is open all the time just the heat vent flap controls the temp into the cabin, this may be the case with your car.
May 5, 2013 at 9:25 PM
