Bottom heater hose does not get hot?
2005 CHRYSLER 300
100,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
LAWRENCE515
I turn the heat on in my car and it doesn't get hot. The two heater core hoses get hot, and the top hose get hot but the bottom one does not get hot. So, l think it could be the thermostat.
Sep 23, 2022 at 4:52 AM
MIKE H R
  • 3,094 POSTS
The problem could be that the heater core is blocked, with one getting hot and the other staying cold. You can back flush the heater core each way a couple of times to try to clean it out with a water hose.
Mike
Sep 23, 2022 at 9:33 AM
LAWRENCE515
The 2 heater core hoses get hot the top hose get hot but the bottom hose does not get hot.
Sep 25, 2022 at 12:07 AM
MIKE H R
  • 3,094 POSTS
The heater core over time, they are known to clog and fail. If you have a heater core that is clogged, it’s not going to be able to pass coolant through. Without the warm coolant going through it, there can be no heat. You can switch the hoses to the heater core to see if there is a blockage. Do it when the car has not been running or hot.
Let us know what you find.
Mike
Sep 26, 2022 at 1:57 AM
