I have seen both the module go out and the heating element go to open circuit. Can I ask if the light goes on when the system is on? If so, I would use a test light to see if the yel/blu wire has power.
This guide can help:
Here is the wiring diagrams for the seat heaters a little larger so you can read it. Also, I would double check fuse #16 in the under hood fuse panel and fuse # 35 in the smart junctions bow with the system on. This can help eliminate the SJB. Check out the images (below). Please let us know what happens.
Images (Click to enlarge)
Feb 9, 2025 at 4:59 AM
