Heated seat turns on and off on its own
60,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BEAR53534
  • 6 POSTS
The heated drivers seat turns on and off on its own. You can turn it off but it will come right back on.
Oct 23, 2018 at 7:34 AM
Good afternoon.
It is possible the switch is bad or the controller. I will attach a diagram of the system for you.
There is a memory module that controls it as well.
I would have someone with a scan tool monitor the system to see if it is working correctly.
Oct 23, 2018 at 8:04 AM
BEAR53534
  • 6 POSTS
Thank you, I will try that.
Oct 23, 2018 at 8:59 AM
Sounds like a plan.
Oct 23, 2018 at 9:02 AM
