heated oxygen sensor (Bank 1 Sensor 2) heater performance
131,000 MILES • 3.5L • V6 • AWD • AUTOMATIC
LINDA HOWARD
PLEASE!!!!!!!!! tell me where this part is specifically located on my car so we can replace
Feb 9, 2015 at 5:28 AM
JDL
  • 16,098 POSTS
Note the picture. Our info shows that for location.
Feb 9, 2015 at 6:17 AM
MNJCHAVEZ
If so where is it located and what is it labeled as? Still Recieving DTC P0032- Replaced B1 S1 o2 sensor w/a Bosch brand- Ohms checked old sensor heater (2 Blk wires)@2.5 Ohms. Troubleshooting if there is a bad relay/fuse (I just don't know if there is a relay or fuse to check) or (what they are labeled as)
Yes- I did disconnect battery to reset code after changing sensor (for approx. 30 minutes)
Yes- The car still has fuel throttle issues. (but not all the time, it is sporadic) But Check engine light is always on.
Mar 4, 2019 at 10:12 AM (Merged)
  • 75,988 POSTS
Here is a guide to help you change the sensor out with the location of the sensors below.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
There is not a fuse or relay for the oxygen sensors. Check out the diagrams (Below) Please let us know if you need anything else to get the problem fixed.
