Neither driver or passenger seats are cooling or heating?
32,000 MILES • MANUAL
CRAIG M
  • 21 POSTS
Neither driver or passenger seats are cooling or heating. The dash lights light up indicating they are on. Dtc code is b14ba:13-48. I am not sure which of the 4 connectors I should be looking at for this issue. 2019 Ford Mustang Bullitt 6 speed manual.
Nov 20, 2026 at 7:10 PM
CRAIG M
  • 21 POSTS
None of the pins show any burn marks
Nov 21, 2026 at 6:52 AM
CRAIG M
  • 21 POSTS
Vehicle details: Standard Transmission
Nov 21, 2026 at 9:56 AM (Merged)
  • 55,797 POSTS
Hello, this is what I found for you.
Ford Special Service Message (SSM) 47814 applies to the 2018–2019 Mustang and identifies a possible loose terminal connection at the driver seat module (DSM).
Your trouble code B14BA:13-48 indicates an open circuit in the driver's seatback thermoelectric device. The :13 portion indicates a circuit-open fault.
Here is where I would start:
1. Locate the driver seat module underneath the driver's seat.
2. Look for connector C341D, which is the 16-pin electrical connector. This is the specific connector identified in Ford's bulletin.
3. With the ignition off, disconnect the connector and carefully inspect the terminals for overheating, discoloration, corrosion, or loose-fitting pins.
4. Pay particular attention to terminals that appear spread apart or pushed back into the connector housing.
5. If the connector is damaged or the terminals have poor contact tension, repair the affected terminals or connector using the appropriate Ford service parts.
https://static.nhtsa.gov/odi/tsbs/2019/MC-10156883-9999.pdf?utm_source=chatgpt.com
Check out the image below.
  • 55,797 POSTS
If the connector looks good chances are the seat HVAC controller has gone out, but I would double check the fuse and the ground please check out the wiring diagrams below to help see the fuse and ground location.
Nov 21, 2026 at 10:00 AM
CRAIG M
  • 21 POSTS
I believe the arrow points to C315 and not the seat module C341d
Nov 21, 2026 at 11:56 AM
  • 55,797 POSTS
Yep, my bad, here is the correct seat control module location and electrical connectors.
Nov 21, 2026 at 5:41 PM
