Heat will not stop
121,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
DEANNALYNN1025
  • 8 POSTS
So i have had issues after issue four months and $1,700.00 later. i had it running but the screen on the console will not turn on, the radio does not work and the heat is blasting on high. I cannot control any of it!
Any ideas?
I had an after market automatic start removed, computer reprogrammed, keys reprogrammed, alternator, starter, battery, intake manifold redone, relay on the fuel pump and washed it! Lol
Mar 28, 2018 at 10:53 PM
KHLOW2008
  • 41,812 POSTS
The radio, monitor and climate control are all linked to the body control module. Under such situations there are a few possible causes.
1. Wiring issue whereby power or grounding circuit is faulty.
2. Control unit faulty.
3. Monitor faulty.
To start off, I would be checking the fuses. There should be trouble codes stored in the system and retrieving the codes should be the priority.
Mar 29, 2018 at 4:08 PM
DEANNALYNN1025
  • 8 POSTS
Replaced the audio fuse. Everything works!
Mar 30, 2018 at 11:39 AM
KHLOW2008
  • 41,812 POSTS
Nice to know you have the problem resolved.
Mar 31, 2018 at 5:46 PM
