Heater will not blow air
225,000 MILES • AUTOMATIC
JENNY79
  • 10 POSTS
I have changed the blower motor and resistor he would not work. Next day it start blowing and working. Two weeks later again it stop blowing. Won’t work on any settings but when you cut it on you can hear it turn over but won’t blow.
Jan 15, 2020 at 3:17 AM
Good afternoon,
I attached a diagram for you to view.
Check the red wire to the resistor for power with the key on when the system does not work.
Trying to narrow the area of failure for it not working.
Jan 15, 2020 at 6:51 AM
JENNY79
  • 10 POSTS
I went and moved the wires around nothing still. also check the connection and everything seem to be together. But it does work for a week and then stops working. I really don’t know that much about cars but what I can research and watch videos to fix on YouTube.
Jan 15, 2020 at 10:45 AM
Okay, you need to check the voltage like I explained to see if power is available for the system to work.
Jan 15, 2020 at 5:32 PM
JENNY79
  • 10 POSTS
Okay, I have to go get a tester. will be trying later today.
Jan 15, 2020 at 9:22 PM
Sounds good.
Keep me updated.
Jan 15, 2020 at 9:24 PM
JENNY79
  • 10 POSTS
Tested the wires to the blower motor and resistor and no power is going to either.
Jan 16, 2020 at 10:50 AM
JENNY79
  • 10 POSTS
Check the blower fuse I listed on the diagram for power. That is what feeds the red wire to the resistor.
Jan 16, 2020 at 11:04 AM
JENNY79
  • 10 POSTS
That’s good.
Jan 17, 2020 at 2:05 AM
Did you check for voltage at the fuse? This is not a visual test, it is a voltage test at the fuse.
Jan 17, 2020 at 3:21 AM
JENNY79
  • 10 POSTS
I used the light up stick thing and it did light up. so I should take them all out 1 by 1? Sorry if I sound crazy really don’t know about cars.
Jan 17, 2020 at 4:34 AM
It should have voltage on both sides with the fuse installed.
If it does, then the wire is open between there and the resistor.
roy
Jan 17, 2020 at 4:37 AM
JENNY79
  • 10 POSTS
How can a chase it or can I make my own ground and connect it to the blower motor or resistor ?
Jan 17, 2020 at 4:51 AM
It is not a ground. It is a power wire.
Somewhere in the harness, there is an open. Where is a good question?
As far as running another wire, you could do that. You could run a wire from that fuse to the resistor and see if it powers up the motor.
Jan 17, 2020 at 5:03 AM
JENNY79
  • 10 POSTS
Okay, but to connect it to the motor would it be the red or purple I connect it to?
Jan 17, 2020 at 5:06 AM
No, it needs to go the red wire at the resistor. That is the wire with the issue.
Jan 17, 2020 at 5:11 AM
JENNY79
  • 10 POSTS
Okay. I’m going to try it and see.
Jan 17, 2020 at 5:13 AM
Keep me updated.
Jan 17, 2020 at 5:18 AM
