I drove the truck for the first time today since the battery had died and it was jumpstarted. I noticed that the heat was only warm on the passenger side and the driver side is blowing cold air. Also, the only spot that air comes out is the dash vents, when switched to defrost or to the feet area it does not switch.
It seems like a panel mode actuator, but that doesn't explain the heat only on once side, that seems like a blend door actuator. I find it odd that both would go at the same time.
I attempted to reset the HVAC actuators by pulling the HVAC fuses and putting them back in, however that did not work. Any help would be appreciated!
Apr 3, 2026 at 6:43 AM
