Heat on drivers side but not passenger
90,100 MILES
BDACEY
I am only getting heat on drivers side of car and cold on passenger side. I looked behind glove box and blend doors are working. Could problem be the blend door on drivers side and if so where is that located? Any help would be appreciated
Nov 19, 2013 at 10:36 PM
  • 110,251 POSTS
Does your vehicle have dual climate control? If so, then it is most likely a blend air door. Keep in mind, you only have one heater core. If one side gets heat, then the core is working and both should get heat. So, the blend air door is my first suspect. Both blend air doors are on the heater core box.
Nov 19, 2013 at 11:05 PM
BDACEY
I do not have dual climate control so would you think it is stil blend air door problem?
Nov 19, 2013 at 11:19 PM
  • 110,251 POSTS
If you don't have dual climate control, then there is only one blend air door. Make sure it is opening fully. Also, check direction vents to make sure they are functioning.
Nov 19, 2013 at 11:44 PM
