heat not working in my mercedes
2000 MERCEDES BENZ ML430
213 MILES
DARRON514
The heat in my Mercedes ML430 is not working the fans are blowing, but cold air is coming out. going to work I tried it several times as I was driving thanking that the car had not heated up it self. I drive bout 40 miles to work and the Mercedes heater never worked
Oct 28, 2013 at 8:15 AM
TY ANDERSON
  • 719 POSTS
There is only a few things that can cause this. First, when the engine has warmed up check the heater hoses (there is only 2 hoses) to make sure they feel the same (temperature both hot). Next, there is a door inside the air condition ducting behind the dash that allows heated air or cooled air to blowing out of dash vents. There is a small motor that controls this door's opening and closing. The issues here could be the motor itself, a broke door or the control module that controls this motor.
Let me know what you find or if you have more questions about what I've said.
Oct 28, 2013 at 1:14 PM
