Heat not working
1,704,697 MILES • V8 • 2WD • AUTOMATIC
SMITH94
What are some ways to check what exactly is the reason my heat is not working. i would like to pin point the problem before i start buying parts and it does not fix the problem.
Note: The mileage listed above is in correct. The correct mileage is 170,469.
Feb 12, 2018 at 6:45 AM
  • 55,746 POSTS
Yes, throwing parts is no fun. Lets start by checking the coolant level. If okay it sounds like you have a blend door actuator that is not working.
Here is a guide to go over to do some quick checks so you can get back to me:
https://www.2carpros.com/articles/car-heater-not-working
Cheers, Ken
Feb 14, 2018 at 2:36 AM
