Heat not blowing out of the side vents
189,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
BLAKOXEN
My heater works very good except for the fact that it will not blow out of the side vents, it only blows out of the defrost and floor but not vents. The car is a non A/C car. Also, my temp control arm is working.
Apr 9, 2022 at 11:20 AM
STEVE W.
  • 15,402 POSTS
It's been a while, but I don't believe the dash vents work on the non-A/C cars. Seems like those only have the off-heat-defrost positions on the control and the ducts were different as well, they only have the floor and defrost ducts. Some were set up, so the dash vents worked with the cowl vents by pulling a handle below the dash but I'm not sure on the Torino.
Apr 9, 2022 at 7:25 PM
BLAKOXEN
Thanks for your response. So let me get this straight, the side vents doesn't vent heat only cool air from outside when the vents are manually open from underneath via vent pull lever?
Apr 13, 2022 at 9:51 AM
STEVE W.
  • 15,402 POSTS
Some connect to the side vents others were just there and went nowhere, but because they made the cars with both A/C and non A/C it was easier to just make the dash the same way. The A/C cars got the ductwork and valving that used the dash vents while the others didn't. They did the same thing with the El-Ranchos.
Apr 13, 2022 at 12:52 PM
BLAKOXEN
Okay, thanks for the response. Mine has the duct on the vents but I'm not sure about the valving.
Apr 14, 2022 at 12:55 AM
STEVE W.
  • 15,402 POSTS
There should be just the short ducts attached to them, most I've seen stop about 3 inches away from the vent pointing toward the middle of the dash. The ones that hooked to the side vents point the opposite way. If you pull the dash panel off, you can see how they are set up.
Apr 14, 2022 at 2:32 AM
BLAKOXEN
Yes, they are the short ducts, but they are connected all the way. Now my quest is if I pull the vent lever will it be cool outside air coming from underneath the vent and out of the vent or just underneath?
Apr 14, 2022 at 2:41 AM
STEVE W.
  • 15,402 POSTS
The only other thing I've ever seen with them was the bare bones cars were connected into the side panels but worked with the flow through vents but that was in the El Ranchos. I wish there were more survivors from those years. Up here in NY they are either Bondo beauties or rust-free state imports with price tags to match. I sold off my last classic mid-winter.
Apr 14, 2022 at 3:14 AM
STEVE W.
  • 15,402 POSTS
Was just wondering what you had found if you had the time to check on the vents. If not no problem.
May 22, 2022 at 12:22 PM
BLAKOXEN
I still haven't found out anything different, I can't receive heat or any air from the side vents just the defrost and floor. I can't figure it out and I tried to trace it, but it leads to nowhere. They have duct so I don't see why they are not useful.
May 22, 2022 at 1:23 PM
STEVE W.
  • 15,402 POSTS
That was common in various vehicles back then. They would make a part to fit the higher-level vehicles and then use it across all models. That was why you had vehicles with radio, heater, and other "delete plates" They punched the holes then blocked the ones off they didn't use. In this case they installed the pieces just to fill the holes.
May 22, 2022 at 2:02 PM
