Heat knob issue no heat?
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
I have heat but no matter which speed it's the same blowing power, very low.
Jan 3, 2025 at 4:17 AM
  • 55,694 POSTS
I would check the coolant level first, and if the coolant is okay, start the engine and allow it to get warm, then grasp the heater hoses to see if they are hot which they should be. Please go over this video:
https://www.youtube.com/watch?v=SNRb6pSwYuU&t=1s
If you check everything and still no heat, I would swap out the air mix door (temperature) blend door actuator. Here is the location so you can check it out. Check out the images (below). Let us know how it goes.
Jan 3, 2025 at 10:16 AM
BHAMDOC1973
  • 2,007 POSTS
I have heat I am talking about the blowing power, feels like it's on speed 1 of the bower no matter what speed i choose.
Jan 4, 2025 at 3:06 AM
  • 55,694 POSTS
Gotcha, it sounds like the cabin air filter is clogged. here is the location so you can check it out. Check out the images (below). Please let us know what happens.
Jan 4, 2025 at 3:23 AM
BHAMDOC1973
  • 2,007 POSTS
turned out blown was bad, thanks.
Jan 7, 2025 at 3:44 AM
  • 55,694 POSTS
"Turned out blown was bad"? Can you please be more specific?
Jan 9, 2025 at 2:20 AM
BHAMDOC1973
  • 2,007 POSTS
Sorry i meant the blower motor.
Jan 9, 2025 at 3:29 AM
  • 55,694 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jan 10, 2025 at 1:04 AM
