Heater issue
133,600 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CARLYLIMOLI
Only my drivers side heat was working, the rest of the car blew cold air. I took apart the glove box and saw that the blend door actuator gear was shattered so I replaced that as well as the actuator. Now my issue is the gear on top won't stay in the position it needs to to blow hot air, so when I want got air I need to manually move the gear to backwards so the hot air will come through but it always eventually defaults back to the same position where it blows out cold. Picture attached.
Nov 20, 2020 at 1:19 AM
  • 110,246 POSTS
Are you referring to the part I highlighted in the pic below? If so, make sure that gear is properly installed. There should be a flat spot in the shaft. If that isn't aligned, it won't properly go on.
If it is correct, the air distribution housing will need taken apart and inspected.
Nov 20, 2020 at 10:51 AM
CARLYLIMOLI
Yes it is that piece! I will try in the morning and let you know, thanks!!
Nov 20, 2020 at 11:06 AM
  • 110,246 POSTS
Happy to help. Let me know the results. Hopefully, you won't need to remove the distribution housing.
Nov 20, 2020 at 1:28 PM
CARLYLIMOLI
Hi Joe, that worked perfect! Thanks! Now to take apart the rear and make hot air get back there!
Nov 21, 2020 at 12:56 AM
  • 110,246 POSTS
If you need help with the rear, just add a new questions and someone will help with that.
Let me know if there is anything I can do to help.
Nov 21, 2020 at 12:46 PM
