Air from vents is not as hot as it should be with heat on high.
Jan 24, 2018 at 11:33 PM
✓Experienced Mechanic
It sounds like you could be low on coolant or you have a blend door actuator that is not working right. Can you please check the level and go over this guide and get back to me?
