Heat issue
170,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
LIMOGUY1510
Air from vents is not as hot as it should be with heat on high.
Jan 24, 2018 at 11:33 PM
  • 55,721 POSTS
It sounds like you could be low on coolant or you have a blend door actuator that is not working right. Can you please check the level and go over this guide and get back to me?
https://www.2carpros.com/articles/car-heater-not-working
Cheers, Ken
Jan 29, 2018 at 3:08 AM
