Heat goes cold for about thirty seconds
220,000 MILES • 3.4L • 6 CYL • AUTOMATIC
ADAM PIETRASKIEWICZ
My niece noticed her heat all the sudden getting cold while she was driving. I checked her antifreeze when engine was cool. Looks like it definitely needs to be flushed .as the car came to normal temperature once the heat started to blow cold, I held down gas a little and noticed the temperature gauge drop a tiny bit and raise back up within about thirty seconds and it started to blow hot again. The other thing I noticed is after the car was running for about thirty minutes, neither cooling fans came on and she has not had any problems overheating. I am baffled.
Apr 1, 2017 at 9:38 AM
  • 55,766 POSTS
It sound like the coolant level is low or the heater core is plugged here is a guide to ehlp you get the problem fixed.
https://www.2carpros.com/articles/car-heater-not-working
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Apr 4, 2017 at 7:25 AM
