Heat gauge malfunction even after three repairs
117,000 MILES
BARNEY12344#
Hello. Back in July my heat gauge was malfunctioning, sometimes working, and sometimes the needle was at the bottom, when it did this, the hold light would flash on my dash. I went to my local mechanic and they put a new thermostat. Every thing was good, then the same symptoms came back, heat gauge on the bottom zero, check engine light on and hold light flashing on the dash. I then took it to my mechanic again, and they put in a new sensor. When the car is idling the heat gauge works, heat is coming.out hot, gauge on the center line (1/2 way)then as soon as I'm driving, the gauge goes down to the zero and my heat becomes Luke warm. Now the mechanic put a new coil restorer in, and again when idling the heat is hot and gauge is on the middle line, but as I drive down the road., the gauge goes to zero and my heat is lukewarm again. check engine light back on.
At this point I am very frustrated. My mechanic says it's fine, as soon as I leave the shop, the symptoms are back and I've paid for 3 repairs so far.
What could the problem be? Do I need another thermostat? Or what?
Please help.
Jackie M
Jan 22, 2020 at 2:25 AM
AL514
  • 5,700 POSTS
Sorry to hear about your troubles. First thing that comes to mind is possible a failing coolant pump, but the check engine light is on because there is a diagnostic trouble code stored in the engine computer. This code will give you some direction into what the problem might be. If you go to your local parts store they can scan the computer for codes. Because you're losing your heat, this means that something if interfering with the coolant flow. This is where the heat comes from. And because the heat gauge goes to zero, this means that coolant is either not flowing correctly or you may have a bad coolant temperature sensor. But get the car scanned and let us know what codes are stored. This will really aid in finding the issue. I am not able to see the car, so I have to go by whatever information you give. So the more information you can find will help.
https://www.2carpros.com/articles/engine-coolant-59420607
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
Jan 22, 2020 at 3:53 AM
