Engine idling rough with a misfire, when I turn the heater on the engine shuts off
2011 CADILLAC CTS
63,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
MONIKANME1
When my car is running it's idling hard with a slight misfire. When I turn my heater on the whole engine shuts off. I have to put the transmission in park and turn the heater off for it to start, what could my problem be?
Jan 31, 2022 at 11:45 AM
  • 110,240 POSTS
This sounds like either an engine vacuum leak issue or the idle air control valve is failing.
Do me a favor. See if the same thing happens when you turn the A/C on. Also, pay attention to see if when this happens, the defroster is on.
Also, take a look through this link. It explains how to locate and repair an engine vacuum leak. If you don't find any, we will need to dig a bit further into the idle air control valve. That component is located on the throttle body and is responsible for maintaining the engine's idle speed.
Take a look through this link as well. It explains how the IAC works and what it does.
https://www.2carpros.com/articles/how-a-idle-air-control-valve-works
Let me know as much as you can. And hang in there. We'll get it fixed.
Jan 31, 2022 at 12:31 PM
