heat direction to the dash and feet
130,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JOEUNGERICHT
Hello, when I have heat direction to the dash and feet, no heat is felt at the feet only dash. Same with defrost and feet no heat at my feet. I have checked thermostat and heater core, also I have checked for air in the system. On a separate issue I get no rear heat. Any ideas what the issue is.
Feb 21, 2016 at 9:34 AM
  • 55,694 POSTS
Can you grasp the heater hoses to the core inlet and outlet to check if they are hot? Please get back to me.
Dec 20, 2016 at 10:09 AM
JOEUNGERICHT
Hi Ken,
Yes, I can grasp the core's inlet and outlet. I have checked both hoses and they are hot. To be on the safe side, I have flushed the heater core already as well.
THIS IS MIKE
  • 686 POSTS
It sounds like the blend system is stuck inside the heater box. The entire dash needs to be removed to access the heater box. It is a 8 hour job to remove the steering column and dash to gain access to the heater box, repair it and re-install.
JOEUNGERICHT
Thanks Mike, I had thought the same thing but wasn't certain. I took the dash partially apart. I wasn't sure where the heater box is exactly. When I had the dash partially apart, I could hear the blend door moving inside the heater box. But when I would direct the heat to my feet, it sounded like the electrical gears were struggling to finish closing or opening the door. In addition, it sounded like the heater box is in the center/passenger side of the dash. Again, I could hear it but could not identify were it was exactly.
Thanks - Joe
THIS IS MIKE
  • 686 POSTS
It's like they started with the heater box and built the car around it. :) Here is where it is located:
JOEUNGERICHT
Oh that looks like too much fun right now. LOL Spring project that is going to be. Thank you, everyone for all of your help.
Thanks - Joe
THIS IS MIKE
  • 686 POSTS
You are welcome, if you run into any problems we will be glad to help.
