Heater only blow through floor vents same time rear view camera stopped working
78,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
DGAG
Have heat only through floor. When switched to defrost or dash only blows out floor. I replaced the actuator above gas pedal this did not fix problem. I found another actuator above that one way up in dash, was that the one I should have replaced? While doing this the rear view camera stopped working. The screen turns blue and goes out. The sensors still work. The picture is located in the rear view mirror. The vehicle is a police interceptor utility.
Apr 23, 2018 at 12:40 AM
MIKE H R
  • 3,094 POSTS
I would start by checking all the fuses, check the wires under the dash see if you accidentally crimped one for the back up camera. the actuator might be defective. there should be a connection on the side, disconnect it and check it for power when you change the settings from floor to defrost and vise versa.
Apr 26, 2018 at 12:30 AM
