Heat and A/C not blowing air, where is the fuse located?
144,000 MILES
FRANK WHITE2
fuse associated with the A/C blower motor. Where is it located, the fuse?
Aug 24, 2023 at 5:20 AM
  • 55,758 POSTS
Sure, it is fuse #22 - 40 amp in fuse panel C. here is a guide to test it and the fuse location in the image below:
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 24, 2023 at 10:54 AM
