climate control no heat
190,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
RANDY WILCOX
I replaced blend door actuator and climate control no heat. i did not see blend door actuator move. do i have a fuse out and if so can climate control still work?
Nov 27, 2019 at 1:38 AM
  • 110,251 POSTS
I attached a picture below of the fuse panel in the vehicle. I highlighted the fuse to check. Do that and let me know what you find.
Here are a few links you may find helpful:
Let me know what you find. Joe
Apr 15, 2021 at 6:44 AM
